Author Topic: knocking  (Read 3026 times)
gnj588d
knocking
« on: July 15, 2015, 21:21:19 »
 There is a slight knocking at low speeds from the rear of my 230,its a regular rhythm
not noticeable above 10 mph  ??? Any ideas.Many thanks, Mike.
Re: knocking
« Reply #1 on: July 16, 2015, 04:24:50 »
Wheel bearing? Or possibly 'something' in the driveshaft/differential set-up which would be more work.
Maybe you can jack up the car at the rear, supporting the driveshafts so that they are in normal driving position, then start engine and put car in gear to see if you can locate the sound easier.
gnj588d
Re: knocking
« Reply #2 on: July 21, 2015, 12:18:56 »
Thanks Cees,will take a look at the weekend.Cheers .Mike.
jameshoward
Re: knocking
« Reply #3 on: July 21, 2015, 12:46:18 »
PM sent.
JH
James Howard
1966 LHD 230SL
