Author Topic: Gearbox Trouble - Continued - Please Help - Update on Symptoms  (Read 3333 times)
An update on symptoms after this morning look: the gearbox is shifting gears higher, but at very high revs and very rough.
It looks like the main thing is too high pressure that we cannot adjust as it does not react neither to adjustment screw turning nor to rod lengthening.
Any clues now?
I had my automatic gearbox refurbished (reputable shop). We installed it back in the car. We went through the pressure adjustments by the book. Yesterday, after a couple of rounds we managed to adjust shifting - it did shift up and down just great, nice and smooth, kickdown working - everything great.
This morning my mechanic took the car for a ride. Made about 2 kilometers. Then from the standstill the car moved, shifted up to 3rd gear roughly and did not shift up anymore. It now shifts up but at very high revs and roughly.
We checked the pressure - it is high on idle, vacuum off, over 6 bar. It does not react to adjustment screw turning - neither direction. It does not react to the linkage rod shortening/lengthening - just stays high.
We have dismantled the diaphragm housing to see if everything is moving there - but it looks ok as far as we could tell.
Any clues what it might be?  :-[
« Last Edit: July 16, 2015, 09:30:44 by Pawel66 »
Re: Gearbox Trouble - Continued - Please Help - Update on Symptoms
« Reply #1 on: July 17, 2015, 13:50:02 »
Maybe a stuck valve in the valve body.  Some times debris lodged in the radiator (transmission tube) moves back to the transmission and causes problems.
« Reply #2 on: July 17, 2015, 15:29:26 »
I had the same thing recently and it was a loose wire at the connection block on the trans.
« Reply #3 on: July 18, 2015, 11:20:55 »
Thank you, gentlemen!
The stuck debris is the shop theory - they will look into that next week if we do not find anything simpler before. The gearbox was refurbished after the aluminum hydraulic clutch ripped open. Cooler, lines etc. were cleaned but there is always a chance that some debris was left somewhere.
The wiring - we will double check all connections at all ends of the wires, thank you for this tip.
