Author Topic: Best Parts sources - Automatic Transmission now needing new bushings  (Read 2800 times)
dldubois
  • USA, FL, Pembroke Pines
Yep,   parked the 280sl in the garage a couple weeks ago and couldn't get it to start.   Got under it and see my automatic transmission linkage has come apart.  Anyone recommend a best source for parts?   I've many times used Millers and wanted to try a few options.
Glad to see good detail on how to replace.   Should I just order the two bushings?    Anything else I might need?    Good thing it came apart in the garage.   Is it just a bushing in the photo below?   It keeps falling apart when I go to move it.    Want to make sure I get everything I need.
Thanks and looking forward to having it out soon.
« Last Edit: July 18, 2015, 01:44:06 by dldubois »
Dana DuBois
1969 280sl
Pembroke Pines, FL
badali
  • USA, Pa, Butler
  • 1966 230SL
Call the classic center and just get 6.  They are cheap enough.  You will have some spares so if it happens again you have them.  It is about an hour job.  Pull the center carpet and remove the shift assembly.  You will have an easier time putting in the bushings in the rods on a work bench.  If you heat them a little in hot water they slip in easier.  Make sure they are in the correct way.  They have a bevel on one side of them.  You will see it if you look closely.  They are very tight...
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
merrill
I buy a lot of parts from Arizona Autohauz.
I agree, buy some extra and it is easier to remove remove the whole linkage and do most of the work on a work bench.
then you only have to complete the linkage / transmission connection on the ground.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
dldubois
« Reply #3 on: July 19, 2015, 15:47:30 »
I have the part number for the bushings on the transmission linkage but can't seem to locate for the shifter itself.   I see there are 2 two o ring type bushings.  Anyone have the part #. Taking the opportunity to replace my chipped shift insert and have the shifter (which was bent) re-chromed.    Too bad you can't run over to the store and buy parts.
Dana DuBois
1969 280sl
Pembroke Pines, FL
sandcrab59
  • USA, MA, Lunenburg
Contact Ton Hanson at the classic center.
He will explain in detail what you need.
Tell him you are a member of the 113 group and receive a 15% discount.
His direct number is 949-598-4842
Tom M
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
