Author Topic: Should Water Pump be replaced during coolant system rebuild  (Read 3522 times)
ddodson1
I'm planning to renew the coolant system on my '65 230SL (high miles), including radiator recore, replacing all hoses, clamps, thermostat.
I've had no issue with the water pump, but should I replace it as a preventative measure?
Re: Should Water Pump be replaced during coolant system rebuild
« Reply #1 on: July 21, 2015, 17:44:30 »
My suggestion is yes, particularly if your sits for extended periods.
Once you do all that renovation, you'll realize that once you get it all back together if you have to remove it all again next year, you'll kick yourself for not doing it when you had the chance...
« Reply #2 on: July 21, 2015, 18:31:00 »
personally I like to just do everything in a given system and put it behind me.  I tend ask myself "Is this the day it dies." if I leave anything undone.
« Reply #3 on: July 21, 2015, 19:28:09 »
A new water pump is a cheap investment.  Go for it!
sandcrab59
  • USA, MA, Lunenburg
« Reply #4 on: July 21, 2015, 21:47:35 »
After major work on an engine out of the car, ALWAYS,  ALWAYS change the water pump. I have been doing that in all my engines for over 50 years.
Tom M
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
