Author Topic: torque setting for flex mounths  (Read 2724 times)
jan lauwers
  • Belgium, Antwerpen, Geel
« on: July 22, 2015, 21:23:40 »
Gentlemen.
I am looking for torque settings for these left and right 4 bolt plates that hold the front flex subframe months to the body of the car. I imagine that they are pretty important, because they are essential to keep the subframe in place. That' s why I am so surprised that I can not find any torque settings. Does anybody know please?
Thanks!
Jan
Jan Lauwers, Geel, Belgium
White 280 SL 1969
Jack Jones
  • Canada, ON, Milton
Re: torque setting for flex mounths
« Reply #1 on: July 23, 2015, 03:20:43 »
Since these are 8.8 grade 8mm bolts, I would say somewhere around 15-17 ft/lb of 20-23Nm.
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
jan lauwers
« Reply #2 on: July 23, 2015, 06:30:59 »
Thank you Jack.
White 280 SL 1969
GGR
  • USA, DC, Washington
« Reply #3 on: July 24, 2015, 08:32:47 »
Be careful not to over-tighten them as the welded nuts on the mounts may strip. Then you are left with replacing the mount or adding a nut from underneath with poor accessibility.
jan lauwers
« Reply #4 on: July 24, 2015, 08:37:11 »
Thank you! Very good advice!
Jan
White 280 SL 1969
