Author Topic: Fixing screws on door hard pockets  (Read 4418 times)
rjfurlan
« on: July 30, 2015, 20:50:16 »
Anyone have any luck fixing broken screws on door hard-pockets? I broke two taking them off.
1) They look like riveted eye bolts.
Anyone know a source for these?
2) I also had trouble with the screws attaching the arm rest.
Anyone know a source for the screws and countersunk washers?
I think I can get the screws, but the washers?
tel76
Re: Fixing screws on door hard pockets
« Reply #1 on: July 31, 2015, 07:47:34 »
I can help you with the washers if you cannot find any nearer to home.
The ones I have are not genuine MB parts they are stainless steel used in the aircraft industry.
I would require the OD and ID as I have several sizes.
Eric
hkollan
  • Spain, Castilla-La Mancha
« Reply #2 on: July 31, 2015, 09:57:36 »
I have made a few of these screws by welding a lock washer to some 5 mm(I think) threaded studs.
Or do a Google for DIN 444 screws which is what they are called, I believe, and you might be able to locate a supplier nearby.
Hans
Hans K, Cuenca, Spain
rjfurlan
« Reply #3 on: July 31, 2015, 21:08:32 »
@tel76, using aviation in my search produced lots of results for thentinnerman washers. Thanks.
@hans, i found some at home depot that might work. Thanks.
Did you rivet them? I gues I need to buy a rivit gun. I am assuming I will need metric? I also need to rivet the door cards.
Any suggestions on rivet gun?
Rich
tel76
« Reply #4 on: August 02, 2015, 06:31:37 »
Hello Rich,
You may have to purchase more than you require, if you send me an address and how many you want I  (or my wife will)  put them in the post, you can have them FOC.
Eric
rjfurlan
« Reply #5 on: August 15, 2015, 17:04:08 »
I could only find 3/4" washers so I made my own. You need
1 pack 10x1 fender washers
1 m5 countersunk screw and nut
8mm, 9mm, 10mm, 11mm sockets
Hammer
« Last Edit: August 15, 2015, 17:24:35 by rjfurlan »
