Become a
Full Member
Emergency Contact List
Source for manual trans sealing ring
Topic: Source for manual trans sealing ring (Read 2180 times)
rjfurlan
August 05, 2015, 14:17:51 »
I am changing the fluid in my manual trans and need the sealing ring for the drain plug, N 00760302410.
Anyone know of a source and size for these. Are they just standard aluminum seal rings I can buy at the aoto parts store?
ctaylor738
Full Member
Platinum
USA, VA, Falls Church
Re: Source for manual trans sealing ring
August 06, 2015, 06:13:40 »
With the PN you should be able to get it from a dealer. You can also take it to a good auto parts store and try to match it. But if you are a true parts geek, you can look up the spec here:
http://www.sl113.org/wiki/uploads/Restricted/Schluessel_Liste_Nr_7.pdf
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
