Author Topic: Putty material  (Read 4844 times)
AndersO
  • Sweden, Skane, Barsebäck
Putty material
« on: August 11, 2015, 10:46:00 »
I have completely disassembled my hardtop, and in many places there is still sealing material that looks and feels like window putty. It is still soft after almost 50 years. Does anyone know what I should use as replacement? I don't want to use anything that hardens, because then I guess it will be impossible to eisassembly the top in the future, if ever needed.
Many thanks,
Andrs
Re: Putty material
« Reply #1 on: August 11, 2015, 15:14:32 »
Re: Putty material
« Reply #2 on: August 11, 2015, 17:18:19 »
Anders,
I have used rope caulk that you can get in most building supply stores. Not sure whether the Mortite brand is available in Sweden. It remains quite flexible.
« Last Edit: August 11, 2015, 18:39:44 by 66andBlue »
PMO956F
Re: Putty material
« Reply #3 on: August 11, 2015, 20:18:18 »
I have just rebuilt my top and used a combination of the tape type and grey sikkoflex non hardening mastic , it worked well for me . i found you have to be careful not to get too much tape under the rear quarter window top chrome trim layers as it can reduce the window aperture slightly , making it even harder to replace those glasses! thats were the sikkoflex worked well
good luck , its a time consuming job but well worth it!
Re: Putty material
« Reply #4 on: August 12, 2015, 01:20:45 »
Sikkoflex = Sikaflex
AndersO
Re: Putty material
« Reply #5 on: August 12, 2015, 11:14:02 »
Many thanks for all replies, they help a lot!  :)
George Des
Re: Putty material
« Reply #6 on: August 13, 2015, 12:19:22 »
In Gernold's excellent hardtop rebuild artilce he uses strip caulk. As I recall when I did my hardtop, I used strip caulk made by 3M. I think I recall getting this at an autobody supply store or on-line. Do an internet search on strip caulk and you should be able to find it.
