Author Topic: big round nut  (Read 2629 times)
piddler
big round nut
« on: August 12, 2015, 21:46:31 »
I had a mechanic friend of mine replace the seals in the steering box on my '67 230SL. He did not have the torque specs and the unit is very tight. I am going to have to remove it and torque everything. Does the big round nut shown in the tech form torquing instructions really need to be removed to set the adjusting screw?. Where would one find the tool to do this? I can probably get it out with needle nose pliers but I have needed a tool like that a couple times in the past. What is the proper name for this tool?
piddler
Re: big round nut
« Reply #1 on: August 13, 2015, 20:08:00 »
nobody knows?
mbzse
Re: big round nut
« Reply #2 on: August 13, 2015, 21:16:41 »
you can find some guidance for this task for instance here (David Petryk):
http://www.davidpetryk.net/Mercedes/Steering.htm
The tool, I guess you call it a pin spanner, see attached
/Hans in Sweden
« Last Edit: August 13, 2015, 21:31:27 by mbzse »
/Hans S
tel76
Re: big round nut
« Reply #3 on: August 14, 2015, 08:10:50 »
You can make your own tool for that particular job, I used the tool that you use to change abrasive disc on an angle grinder, cut off one peg, make another peg to suit, re-drill the hole in the handle and fit the new peg, tack weld into position.
Eric
