Author Topic: Oiling main shaft bushes in distributor  (Read 2928 times)
rjfurlan
« on: August 16, 2015, 22:45:43 »
I want to oil The main shaft bushes in distributor. I can not get the knob to move. It has been a while, iI forget, do pull, push, turn cw, ccw?
Re: Oiling main shaft bushes in distributor
« Reply #1 on: August 17, 2015, 05:15:42 »
It should turn either direction. It is easy to damage when using a lot of force.
rjfurlan
« Reply #2 on: August 17, 2015, 14:27:53 »
Thanks Joe.
It must be corroded shut. I will soak it with penetrating oil and try again.
Rich
