ive done the linage adjustments. Car is idlling nicely. It does still pop in the intake box a bit. Ill do some more fuel adjustments when get the gas tank back in the car. right now i have a temporry gas tank hooked up from an old plastic gas can. Cant believe how easily a car this old starts up, its starts with first turn hot or cold.
The fuel injection pump in this car was totally locked up when i first got the car and I went through hoops to free up the pistons. it was stiff to turn at first but eventuall all the stuck pistons freeded up after lots of sea foam, carb cleaner, trans fluid , soaking the whole thing up to its neck in chem dip. I didnt know if it would run at all but was happy not to have it sent out for a rebuild. I think the internals are very durable.
