No I did not do a trial fit but I did test a test fit and pushed down on middle pan cover around rear seal,and I did notice the fiber crush out and then I though I should trim those which I did. Its too late now as I've buttoned everything up, the Water pump I do plan on replacing.
This is all very good information and I really appreciate the guidance. I;m learning a lot.
Pic below is at what stage I am right now.
Which is: New pistons, block bored 87mm crank bearings, chain, new seals on cover plates, wire harness decreased and wire wheeled rust off then painted.
