Author Topic: adjusting trans neutral switch  (Read 3669 times)
piddler
« on: August 22, 2015, 00:11:48 »
I replaced the cable from the transmission to the trans neutral/backup light switches. I checked the switch without the cable installed to be sure that it worked properly. Now I cannot get the cable adjusted to operate the switch properly. I am checking with ohm meter and the circuit stays closed in park, reverse and neutral now. I have adjusted the cable to just about every position and have a lot of results. None of which have been correct.
Am I missing something?
Thanks in advance, Pete
ctaylor738
  • USA, VA, Falls Church
Re: adjusting trans neutral switch
« Reply #1 on: August 22, 2015, 15:13:45 »
Not sure I understand.  You should have a closed circuit to the starter (terminal 50, purple wire I think) in P and N, and to the backup lights in R.  Is this what you are seeing?
I have also had trouble with this adjustment.  I have found the best starting point to be putting the trans in N, putting the switch in the N position, and adjusting the cable to that length.
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
piddler
« Reply #2 on: August 24, 2015, 12:58:09 »
Thanks. You are correct about the closed circuit on the switch. I hope to get back to the car today. I will follow your advice on the adjustment.
I have worked mainly American and British cars and I must say that this Mercedes has been a challenge.
piddler
« Reply #3 on: August 25, 2015, 09:51:33 »
Thanks for the tip. The simple things in life can bring joy, or frustration.
« Reply #4 on: August 26, 2015, 02:16:57 »
Be certain to clean and  lube the pivot at the cable end/transmission connection or the cable end will bind causing the cable to flex and throw the adjustment off.
