Author Topic: oil pump specifications  (Read 3876 times)
220sebCoupe
« on: August 25, 2015, 10:59:12 »
Hello forum
I've recently pulled out my engine from the coupe and have slowly dismantled. It was tired with some broken rings and worn bearings. I'm slowly gathering all the bits to put it back together again, but I'm trying to find specifications for the oil pump, namely, the allowable clearance between the oil pump gear teeth before it becomes serviceable. I'm not opposed to buying a new one, but these are $1000 aussie peso's and I will happily avoid the expense if it's possible.
I have the BBB but I can't see a spec for the pump in it.
sandcrab59
  • USA, MA, Lunenburg
Re: oil pump specifications
« Reply #1 on: August 25, 2015, 11:05:31 »
Contact Joe (JA17) he will know what you need.
Tom M
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
