Author Topic: oil pump specifications  (Read 2671 times)
220sebCoupe
« on: August 25, 2015, 11:26:37 »
One for JA perhaps???
I've recently pulled out my engine from the coupe and have slowly dismantled. It was tired with some broken rings and worn bearings. I'm slowly gathering all the bits to put it back together again, but I'm trying to find specifications for the oil pump, namely, the allowable clearance between the oil pump gear teeth before it becomes serviceable. I'm not opposed to buying a new one, but these are $1000 aussie peso's and I will happily avoid the expense if it's possible.
I have the BBB but I can't see a spec for the pump in it.
ctaylor738
  • USA, VA, Falls Church
Re: oil pump specifications
« Reply #1 on: August 25, 2015, 15:14:35 »
See attached from the technical data book for 1966.
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
220sebCoupe
« Reply #2 on: August 25, 2015, 22:25:27 »
Thanks Chuck
