Author Topic: Help With Data Card "Fahrzeug-Daten"/ Never Mind  (Read 3513 times)
250SLFranco
  • USA, OR, Portland
« on: August 26, 2015, 21:27:46 »
I have attached a copy of my original "Data Card" or the "Fahrzeug-Daten".  I think this is the card referred to in blogs when members want to know the original carpet, interior, etc.
I would appreciate help with interpretation of the numeric codes entered in each category.  The back of the card gives me the German-English translation.
I want to replace carpets and eventually seat covers as well as repaint...I believe this is the information I will need...
Any help is greatly appreciated.
250SL Franco
 :)POSTSCRIPT: NEVER MIND...the Pagoda SL Group site is so thorough!  I did the research and found everything explained and everything I needed with a little more research!
« Last Edit: August 26, 2015, 23:01:07 by 250SLFranco »
Re: Help With Data Card "Fahrzeug-Daten"
« Reply #1 on: August 26, 2015, 22:26:52 »
Hi Franco
You need to have a good read through the Tech Manual and in particular this area that will explain each line by line of the Data Card to you.
http://www.sl113.org/wiki/DataCard/Start
Re: Help With Data Card "Fahrzeug-Daten"/ Never Mind
« Reply #2 on: August 28, 2015, 16:05:18 »
You may want to go back and blank out the key code lines on the data card!
