Author Topic: Europa TR mono speaker wiring  (Read 2953 times)
rjfurlan
« on: August 29, 2015, 16:55:25 »
Anyone know how to connect the speaker on a europa tr mono. It allows two speakers to be connected. The two pins close together are labeled 5  and the othe two are labeled 2.5. There are two + labels over the two 5 pins.
I think i should use the two 5 pins, but which is the + and which is the -, or does it matter?
Re: Europa TR mono speaker wiring
« Reply #1 on: August 29, 2015, 18:04:19 »
Correct, use the two in the middle labeled 5 (Ohms) and polarity does not matter.
The two black plugs are for connecting an automatic antenna trigger.
There is a wiring diagram in the technical manual showing the wiring: http://www.sl113.org/wiki/Electrical/RadioAndAntenna
rjfurlan
« Reply #2 on: August 30, 2015, 13:45:55 »
Thanks Alfred, i guess I did not read far enough down in the installation manual the first time.
