Author Topic: WRD question  (Read 2420 times)
Steven A
  • Australia, Western Australia, Cottesloe
WRD question
« on: August 30, 2015, 04:04:08 »
Hi All,
Hoping some-one can educate me here....
With a very early 230SL (1st registered in 1964), with reference to the attached photos, is it possible to remove/adjust the steel plunger (and steel plunger nut) within the brass slug?   Does one have to remove the very small roll pin, or is there a nice easy way?  I suspect that possibly the early 230's had a different WRD to later models (with the WRD shared with other marques using the Bosch injection system)?.
Any thoughts appreciated.
With thanks
Steven
1964 230SL Manual RHD
1957 Series 1 Land Rover
1975 Range Rover
ctaylor738
  • USA, VA, Falls Church
Re: WRD question
« Reply #1 on: September 01, 2015, 12:55:34 »
Since you're not getting any replies, I'll take a shot at it.  I took a 230's apart several years ago.  To remove the air slide, I think you need to remove the pin and the adjuster which I believe is used to adjust the starting point of the slide.  The whole thing will be easier if you take to rest of the WRD off the pump.  Be sure to keep track of the shims.
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
