Author Topic: 123ignition and spring  (Read 3567 times)
rjfurlan
« on: August 30, 2015, 14:09:14 »
Sorry to bring this topic up again, but do I need a longer spring or not? Every other post says the opposite. My current feeling is just pull out the 051 and put in the 123, then time it. I believe 123 recommend not adding a longer spring. Thanks
kampala
  • USA, CA, Beach Cities
Re: 123ignition and spring
« Reply #2 on: August 31, 2015, 01:31:06 »
rjfurlan,
The link that Hauser provided is probably the most direct and specific information you may find.  I was also quite confused, so I posed the "spring" question to Ed at 123IgnitionUSA --- give him a call if you plan on purchasing from him.  He was clearly against putting in a longer spring.  He sent me a photo of a problem very similar to what Andy (in the link Hauser provided) experienced.
I cannot provide my specific experience as the 123 has only been running for about 2000 miles on the 280.  I left the original shorter spring in place based on the information from Ed --- time will tell if I should have gone with a longer spring.
250sl - later - manual
280sl - 1971 - Auto - LSD
VincentR
« Reply #3 on: August 31, 2015, 08:23:15 »
Hello All
Use the same design spring but around 2cm long.
I didi it and it fits perfectly.
Best regards.
Vincent R
280sl 1970 France
