Please note that decals varied to some degree between US delivery cars, and Euro version.
Attached two sheets with markings, suitable for US Pagoda cars.
However, some are not for Pagoda; they were used on earlier and other M-B types of cars.
No 7, 17, 18 and 19 in the sheets. No10 I think is for later cars than W113, also
Vorsicht
Bosch Ignition coil (which btw was black from factory)
Verunreinigten Filter instruction. Not for Pagoda
Gefrier Blue star to the low left on windshield. Indicates antifreeze filled from factory. The type here (No19) was for earlier Mercedes cars
Nach Gebrauch... on metal sleeve on late type jack (not the spiral threaded one w separate handle)
Attention High Pressure.... Coolant header tank
Caution Only USe Oils.....
Achtung!............ Refers to spark plug specifications
/Hans in Sweden
