Author Topic: Water Pump Identification  (Read 1862 times)
dirtrack49
« on: September 20, 2015, 15:34:08 »
I removed the water pump from my 66 230SL that has a Kuhlmeister installed A/C. I took a look at the part number and found it to be 121-201-01-10 which comes back to a M180 motor. So since I just received what I thought would be the correct pump with part number 115-200-16-20, which is the long 3 hole pump for a 230SL, I measured both units to see if they were the same. I was surprised to find that the new pump is a little bit longer by about 1/16th of an inch.
I am guessing that this pump was either a replacement, although it looks to be original to the car, or it was part of a dealer installed A/C unit package.
Anyone know the origin of this water pump and why it would be on this car?
Is the new water pump the proper replacement?
Thanks for any and all help.
