Author Topic: Long Fuel Pump Removal Question  (Read 5142 times)
vande17941
  • USA, CA, Irvine
« on: September 29, 2015, 05:54:11 »
I have the 230sl down for a few weeks for other work. So, I figured I'd drain the fuel tank (looks great, strainer clean) and replace the fuel filter.
I would also like to check the inlet filter on the fuel pump (long style). The canister around the pump is making it a bear. It has only two holes...one for the inlet hose, one for the outlet. Even loosening the canister mounting screws, I can't get the canister to move side to side enough to even access the hose clamps attaching the hoses to the pump. I need to get those hose off so I cab drop the protective canister or at least get to the inlet.
Somebody, please tell me the miracle secret! Thanks
'66 USA (1967 model Year) 230sl, 4-speed Manual, Driven Like a Real Car! Set up with KYB Stiffer Shocks, and Motor Mounts w Urethane Inserts Underneath, 3-point Belts, Headrests Installed 🚗
1986 560sl Cabernet & Palomino (not recommended)
2001 SLK320 Sport AMG Silver & Black
mbzse
Re: Long Fuel Pump Removal Question
« Reply #1 on: September 29, 2015, 06:37:05 »
Quote from: vande17941
.../... I need to get those hose off so I cab drop the protective canister.../...
Well, one suggestion would be to go with the Alexander the Great approach - just cut the fuel hoses off! If the hoses are old and dry, you are wise to replace them anyway
/Hans in Sweden
« Last Edit: September 29, 2015, 06:44:43 by mbzse »
/Hans S
vande17941
  • USA, CA, Irvine
« Reply #2 on: September 29, 2015, 16:57:02 »
Fuel hoses are perfect...like new. Guy before had them done. But I want to be sure that strainer is clean. I don't want to cut the hoses
twistedtree
  • USA, MA, Gloucester
« Reply #3 on: September 30, 2015, 11:59:11 »
I think you just have to take everything apart.  Remove the fuel lines then the cover, then the pump.  Some of the work required to service these cars is NOT a shining example of German engineering.
Peter Hayden
1964 MB 230SL
1970 MB 280SL
2011 BMW 550xi
« Reply #4 on: September 30, 2015, 12:51:01 »
crow_foot wrench?
ctaylor738
  • USA, VA, Falls Church
« Reply #5 on: September 30, 2015, 19:16:35 »
If the tank strainer is clean and you aren't having any fuel starvation, no need to check the pump filter.
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
vande17941
  • USA, CA, Irvine
« Reply #6 on: October 02, 2015, 05:54:13 »
WRONG....the tank strainer was 100% perfectly  clean. The fuel pump strainer was 75% gummed up with "gas jello". Don't think just  because  one  is clean  the other is too. I was told that by a local guy who has been working on these for 30years...and he was right. Good thing I checked.
Figured out easily how to remove the hoses....remove the outlet hose fitting with a 19mm. Put a screwdriver through the same housing cover hole so you can get the screwdriver on the hose clamp and remove the hose clamp from the inlet. Was a piece of cake....just had to think about it for a minute or two.
« Reply #7 on: October 02, 2015, 08:29:38 »
There is always a method to the MB madness  ;D ;D ;D
« Reply #8 on: October 02, 2015, 15:40:37 »
No, there is always a method to MB madness. Have to replace a hydraulic cylinder in one of the doors on the 600 and the MBC price is..............
        $2,654.00
