Please check out joining the
Emergency Contact List
for help during your travels!
Body, interior, paint, chrome, and cosmetic items
Tachometer gear bushing
Topic: Tachometer gear bushing (Read 2430 times)
vande17941
Full Member
Senior
USA, CA, Irvine
October 13, 2015, 01:37:03 »
Reading in the technical section of this site, I found that a worn bushing could be shimmed. I see that using fuel injection washers works. However, using one is just a tiny bit too thick for me. Does Mercedes make specific shims for this purpose?
'66 USA (1967 model Year) 230sl, 4-speed Manual, Driven Like a Real Car! Set up with KYB Stiffer Shocks, and Motor Mounts w Urethane Inserts Underneath, 3-point Belts, Headrests Installed 🚗
1986 560sl Cabernet & Palomino (not recommended)
2001 SLK320 Sport AMG Silver & Black
UJJ
Full Member
Silver
USA, CA, Grass Valley
Re: Tachometer gear bushing
October 13, 2015, 11:32:59 »
I do not know if MB has these shims. I bought them from McMaster Carr, they have many different thicknesses available. Unfortunately I do not remember the ID and OD otherwise I would have added the proper link for you.
Urban
Urban Janssen
Grass Valley, CA
1968 280 SL - 4speed manual
173 anthracite grey
Full Member
Platinum
USA, OH, Blacklick
Reply #2 on:
October 13, 2015, 13:54:11 »
McMaster/Carr has round steel metric shims. The inside diameter needs to be 14mm I believe. You can also replace the thrust bushing with a new one.
