Author Topic: Hazard Warning Switch Diagram  (Read 7312 times)
PeterPortugal
  • Portugal, Faro, Lagoa
« on: October 14, 2015, 09:11:40 »
Hi All,
I recently picked up a Bosch hazard warning switch from ebay - part No 0 336 285 001. It is a big old beast and I wondered if it has an integral relay?
I have a suitable hole in my dash and am ready to fit it. Does anybody have a wiring diagram? My car is a 1963 and there is no wiring present for hazard lights at the moment so it's a new install.
1963 220se Cabrio
1968 280se Coupe
Re: Hazard Warning Switch Diagram
« Reply #1 on: October 14, 2015, 09:46:19 »
Coloured Wiring Diagrams are here in the Technical Manual but they are only available to Full Members.  :P  :o
Full Membership is only $30 pa and you will have full access to all of the Tech Manual including the Linkage tour, critical to keep your car in tip top condition, the Pagoda Notes from No. 1 and will receive Pagoda world twice a year.   ;) ;)   8)
Membership Administrator
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
PeterPortugal
« Reply #2 on: October 14, 2015, 10:18:24 »
Nice one Garry. If it tells me what I need to know then I'll gladly pay the thirty bucks.
1963 220se Cabrio
1968 280se Coupe
« Reply #3 on: October 14, 2015, 11:01:48 »
Hello, Peter,
Wiring the hazard flasher is pretty straight forward  ;D ;D
You can buy the 6 pin bushings and the 6 pin plug from MB.
R = Right Side Indicator (black  wire with green runner)
L = Left side indicator (black wire with white runner)
You can pick up these two feeds from the multifunction switch plug under the dash.
30 is the '+'  feed. I used the '+' feed on the door light switch, but ideally should come from the fuse box.
31 is Earth or Ground.
You have to interrupt the feed to the normal flasher. So, Cut the wire (terminal marked 15 on the flasher unit) and the live side goes to terminal 15 and the other side to 49a.
Job done.
The internals of this flasher unit are all mechanical. Our UK MB Club Technical Director just converted one to these for me to electronic operation. He used a multifunction relay from a W201, but that's another story.
« Last Edit: October 14, 2015, 13:40:50 by Naj »
« Reply #4 on: October 14, 2015, 11:21:21 »
Thanks Peter,
Welcome as a Full Member to the Group.
I hope Naj’s reply and access to the wiring diagram answers your question and problem.
PeterPortugal
« Reply #5 on: October 14, 2015, 11:24:14 »
Hi Garry / Naj,
Thanks for your help. Naj's email was comprehensive and should be enough but any issues and I will refer to the wiring diagrams.
Cheers
1963 220se Cabrio
1968 280se Coupe
PeterPortugal
« Reply #6 on: October 14, 2015, 13:50:50 »
Hi Naj,
Just a double check.
On my "normal" (cylindrical canister type) flasher unit, terminal 15 is fed from Fuse No 5 (switched +ve i.e. live when ignition switch is turned to position 1 or 2).
If I understand you correctly I do the following
1. Disconnect the feed to flasher unit terminal 15 from Fuse No 5.
2. Run a new wire from Fuse No 5 to terminal 15 of my new hazard warning switch.
3. Reconnect the feed to "normal" flasher unit terminal 15 to terminal 49a of my new hazard warning switch.
Would appreciate your confirmation.
Regards
1963 220se Cabrio
1968 280se Coupe
PeterPortugal
« Reply #7 on: October 14, 2015, 15:39:16 »
Hi again Naj,
I have looked at the wiring digarams (1963 230sl vs 1970 280sl) and it seems to show that this new hazard switch actually replaces the normal flasher unit.
On the 1970 280sl diagram the switched +ve supply (originally to the flasher unit terminal 15 on the 63 230sl)  is now routed to the new hazard switch terminal 15 (this is as you described).
On the 1970 280sl diagram the new hazard switch terminal 49A is connected to the steering column stalk connection 54 (instead of the wire from terminal 54 of the normal flasher unit as per the 63 230sl).
Do you know what the difference is between taking this "direct" approach as described above vs routing through the old flasher unit as you described? Electrickery is not my strongpoint !
Cheers
1963 220se Cabrio
1968 280se Coupe
« Reply #8 on: October 14, 2015, 17:00:48 »
Hello again, Peter,
AFAIK, the Bosch 0 3336 285 001 should be wired as I explained.
I have a Hella unit on my car which works the same.
I believe the later Bosch 0 336 285 002 is all electronic and is wired they way you are describing, not needing the current indicator flasher unit any longer.
I guess you could easily try and see what you have.
PeterPortugal
« Reply #9 on: October 14, 2015, 18:17:21 »
Naj,
I am going to experiment and will get back to you.  Whilst trying to research this I came across this useful website identifying Bosch terminals for wiring.
http://www.type2.com/library/identifi/bosterm.htm
Useful info but probably on here somewhere already !!
Cheers
1963 220se Cabrio
1968 280se Coupe
PeterPortugal
« Reply #10 on: October 20, 2015, 15:19:13 »
Hi Naj,
Your suggested wiring arrangement worked perfectly.
I can see from other posts that you regularly help people out so it's a very big thank you from me for sharing your knowledge.
Regards
1963 220se Cabrio
1968 280se Coupe
