Author Topic: What is the approximate weight of both the engine and automatic transmisison?  (Read 3019 times)
CJHenderson
  • USA, AR, Benton
What is the approximate weight of both the engine and automatic transmission? IF it's under 500 Lbs. I can use the hoist but if more then I have to drop it down under the car.
1950 MG-TD
Rolf-Dieter ✝︎
  • Canada, ON, London
I recommend a read here -----> http://www.sl113.org/wiki/Engine/Overhaul
If I had this project I would also check our tech manual under Engine and if no one ever listed the weights then I would PM Joe Alexander or the Benz Dr. (Both I am sure have the answer at there fingertips).
Good luck
Cheers,
Dieter
.. and if you use the search function you'll find this: http://www.sl113.org/forums/index.php?topic=7714.0
CJHenderson
  • USA, AR, Benton
Thanks for the information I went to the link and found out that I will be able to lift the motor and transmission.
1950 MG-TD
