George, too answer your questions. I always felt the interior light was not that great, it did not
Provide much light. To improve matters I used LED tape hidden under the dash. This is totally invisible,
Hidden out of sight. Wires soldered to the end of the tape were then attached to either end of the
Original interior light bulb with the use of wire eyelet connectors. The shape of the bulb allows a simple
Push fit. Everything is easily removed if needed.
