Author Topic: Needed: Pictures of hood hinges under the fenders  (Read 5931 times)
cabrioletturbo
  • Canada, Ontario, Ottawa
« on: October 27, 2015, 13:54:07 »
Does anyone have pictures of how hood hinges are bolted to the inner fenders?
My inner fenders are pretty bad and someone previously welded the hinges, so I am trying to restore it back to original and need a few pictures if possible.
Apparently there is some sort of plate on the inner fender which the hinge is bolting onto? My car only has cut-out slots for the bolts to go through.
An original picture would be appreciated, both from under the fender and the engine bay, with hinge taken off.
Thanks in advance.
« Last Edit: October 27, 2015, 14:05:24 by cabrioletturbo »
Igor
WRe
cabrioletturbo
Re: Needed: Pictures of hood hinges under the fenders
« Reply #2 on: October 27, 2015, 17:47:44 »
Thanks WRe, I had got the red picture, the other one is great!
Igor
Scottcorvette
« Reply #3 on: November 04, 2015, 07:54:17 »
Mine didn't have any kind of plate, just holes and slots in the fender, and there were large J-nuts through the slot with the bolt going through the hole into the J-nut.
cabrioletturbo
« Reply #4 on: November 04, 2015, 13:24:44 »
Scott,
These pictures are just perfect, thank you so much.
Igor
« Reply #5 on: November 04, 2015, 17:57:10 »
You're welcome! ;D
Scottcorvette
« Reply #6 on: November 04, 2015, 19:22:21 »
Hardly Stick, I took them of my car last night!
You are welcome though....
These are the J-nuts/cage nuts that were in the body. one of mine was damaged I think so I need to get more, I am hoping MB do them or I can find some the same.
« Reply #7 on: November 04, 2015, 19:35:03 »
I believe the same nuts are used for the seat rear mounting points and also the soft top lid hinge?
Scottcorvette
« Reply #8 on: November 04, 2015, 19:36:35 »
I'll have to take a look, I need the ones for the seats and the bolts too.
« Reply #9 on: November 05, 2015, 21:54:25 »
It was my sarcastic attempt at humour. The reference photos in the Dropbox link are mine, sorry to appear hostile!
Scottcorvette
« Reply #10 on: November 06, 2015, 08:39:19 »
Not at all, I hadn't seen the drop box ones, they are some interesting pictures, I wish my shell was in that good a condition.
I notice the hood supports that Cab turbo is asking about are completely different on that car to my car.
