Hi Joe and Naj,
The above two last posts are so clear and concise, they should be in the TM exactly as written, if not already. I just did all of that a couple of days ago and it worked perfectly. I think it's clockwise, not ccw, that you twist the big screwdriver to get the distributor drive gear to skip a tooth. I actually was too far clockwise when I dropped my drive gear in the hole. It's hard to judge since it twists as it engages the gear in the block. I had to use the screwdriver and turn the gear eight teeth clockwise to get where I wanted to be - one tooth ccw from where it dropped in.
It's really great to have all you experts who know all the tricks to getting it right.
Thanks much.
Tom Kizer
