Author Topic: removing engine torque stabiliser on 280se 3.5  (Read 4517 times)
rutger kohler
« on: November 11, 2015, 07:29:51 »
Hi, I am going through the front of my enginebay cleaning it and painting. I would like to remove what i would call the engine torque stabiliser.
It consists of what looks like a small shock absorber and is located towards the front of the engine, on the right hand side.  i have attached a photo with two very faint arrows showing the engine bracket, and the black shock absorber mounted to the chassis through a subtantial aluminium bracket.
My questions (a), can I remove this with the engine at rest without blocking the engne up, and (b) what was the top engine bracket (top arrow) finish ex the factory, ie zinc or gold passivate?
1969 280 SL Manual gear shift
1972 280SE 3.5 auto
Re: removing engine torque stabiliser on 280se 3.5
« Reply #1 on: November 11, 2015, 15:04:53 »
On my 2.8L six, it has studs on either end with  nuts. It is just a hydraulic damper with no spring force. You can take it off whenever.
rutger kohler
« Reply #2 on: November 12, 2015, 05:57:12 »
Hi Wallace, thanks for that have since removed.
1972 280SE 3.5 auto
