Author Topic: Missing clutch parts  (Read 3907 times)
gordon
  • United Kingdom, England, Burntwood
« on: December 03, 2015, 12:31:19 »
Hi, i am getting the parts together to convert my 230 from auto to manual. The pedal box i have is missing the clutch master cylinder push rod. I assume that it is a simple non adjustable rod with a boss on the end for the pivot pin to pass through.
Can anyone tell me what the dimensions are for me make a new one?  [Thankyou all for help with previous questions] Gordon
Re: Missing clutch parts
« Reply #1 on: December 03, 2015, 20:47:20 »
I'm pretty sure that there's an eccentric to adjust free play on that rod. I would try to find a used rod which shouldn't be too hard to do.
gordon
« Reply #2 on: December 04, 2015, 20:27:54 »
Yes, i have the pivot which is eccentric and appears to give approx 5mm of adjustment  When the push rod is in place should it bear on the clutch piston, ie with no pedal travel before it displaces fluid?
« Reply #3 on: December 05, 2015, 01:55:32 »
I imagine you would want a small amount of free play at the push rod as it rests in the piston so that the piston canl return to the rest position when you release the clutch.
« Reply #4 on: December 05, 2015, 02:47:15 »
I'm with Dan (Benz DR).  It's really annoying fighting a clutch or brake master cylinder that doesn't return all the way.
gordon
« Reply #5 on: December 05, 2015, 09:01:30 »
Thankyou all, if i cant find a pushrod i will make one up bearing in mind your comments.
ctaylor738
  • USA, VA, Falls Church
« Reply #6 on: December 05, 2015, 15:37:51 »
PN 110 29018 39.  A bit pricey at $114 list.
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
