Author Topic: Control Shaft Connections  (Read 3338 times)
mocstar
« on: December 03, 2015, 22:48:10 »
Hi guys,
I had to drill out the two bolts connecting the control shaft to the air intake and can't seem to find these replacement bolts anywhere. (see attached pic)
Can someone point me in the right direction?
Much appreciated,
Matt
Re: Control Shaft Connections
« Reply #1 on: December 05, 2015, 03:03:54 »
Yes these are centering bolts. They have a tapper under the head to center-up linkage position exactly. Try to order them the MB Dealer or Classic center.  Otherwise find some good used ones.
« Reply #2 on: December 05, 2015, 03:28:30 »
450SL ( and others ) manifold studs will work nicely. You will need to trim some of the threaded end off the longer portion to the correct length.
mocstar
« Reply #3 on: December 08, 2015, 01:35:39 »
Thanks so much for your responses. You have saved me a lot of time.
Cheers,
Matt
