Please check out joining the
Emergency Contact List
for help during your travels!
Diff oil level
Topic: Diff oil level (Read 2953 times)
Madmerc
Diff oil level
December 07, 2015, 17:08:09 »
Hi guys I have taken my 230 Sl for a long drive from Sydney to Melbourne who's is about 900 klm
And all went well except I noticed some diff oil weeping from the front of the differential I had replace all oils a few days before my trip and my concern was have I put in to much diff oil
badali
Full Member
Platinum
USA, Pa, Butler
1966 230SL
Re: Diff oil level
December 07, 2015, 17:50:25 »
Leave the car flat on the ground and slide under to remove the fill plug. Place a pan under before you do this and if there is too much it will drain to the proper level.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
Associate Member
Platinum
Canada, ON, Port Lambton
Re: Diff oil level
Reply #2 on:
December 07, 2015, 18:26:28 »
If it's leaking from the front you may have a worn pinion seal. Bit of work to replace it.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
Madmerc
Re: Diff oil level
Reply #3 on:
December 07, 2015, 20:36:36 »
Thanks guys will check oil level
jameshoward
Associate Member
Platinum
United States, New Jersey (formerly of London)
Re: Diff oil level
Reply #4 on:
December 08, 2015, 08:02:58 »
Check the breather on top of the diff also, as that's a possible source. It may also be that the oil foamed up and has leaked from the breather. You can unscrew the breather to check it's clean.
James Howard
1966 LHD 230SL
Diff oil level
