Author Topic: Losing power  (Read 2722 times)
Madmerc
Losing power
« on: December 09, 2015, 01:56:03 »
Hi guys I'm on the free way  and I'm starting to lose power and the engine starts to cough and  splert any ideas on what it could be  only happens under load  cheers thanks
Re: Losing power
« Reply #1 on: December 09, 2015, 03:08:09 »
Sounds like the classic "fuel delivery" problem. Letting the engine rest for a period or topping off the fuel may offer some temporary relief. Hooking up a fuel  pressure gauge to the system when the problem is going on will help diagnose the problem. When the fuel pressure available at the engine drops below 10 lbs problems begin.  Make sure the main fuel filter is clear, the electric fuel pump screen is clear, the fuel tank screen is clear, and the entry port for fuel into the tank "flower pot"  is clear.
dante53
Re: Losing power
« Reply #2 on: December 09, 2015, 07:49:36 »
I had a severe issue like yours. Cleaning the fuel pump filter (filled with rust) revealed to be a temporary solution. I finally had my fuel tank removed, cleaned and coated inside. Problem fixed. Be carefull. W113 fuel tanks have a complex design. Have the job done by an expert that avoids clogging the  fuel return line.
Madmerc
Re: Losing power
« Reply #3 on: December 10, 2015, 09:01:02 »
Thanks guys you hit the nail on the head with this one yes some trash in the fuel thanks much appreciated
