Author Topic: Brake reservoir float  (Read 5799 times)
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« on: December 13, 2015, 14:33:32 »
I've just been cleaning out my brake fluid reservoir and on one of the level sensor floats the rubber stopper that holds the float onto the brass rod has perished.  How can I achieve a permanent repair?  Is there a replacement sensor or float?  Failing that, I've thought about epoxy to replace the rubber.  Keeping in mind that this is bathed in brake fluid forever, does that seem feasible?  Other suggestions?
rutger kohler
Re: Brake reservoir float
« Reply #1 on: December 13, 2015, 18:27:05 »
Hi, if you can't fix it Santa is rumoured to be bringing me a new brake reservoir for Xmas. If you wanted to pay say $US20 plus postage from NZ you can have the whole old brake reservoir with the two floats in it.
1969 280 SL Manual gear shift
1972 280SE 3.5 auto
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #2 on: December 13, 2015, 23:54:26 »
Try a piece of rubber hose that fits around the pin and snuggly in the float.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
« Reply #3 on: December 15, 2015, 04:15:17 »
Rutger,
Generally new reservoirs don't come with the level switches.  You might want to hold off giving yours away.
Raymond
« Reply #4 on: December 16, 2015, 22:59:44 »
I've simply removed the float and post from one of the chambers temporarily.  I regularly check for leaks and fluid levels so it's not like I'll ever need it.  Meanwhile, Rutger already has his new one an it did come with new float switches.  Sometime after Christmas, we'll have two happy brake systems.
« Reply #5 on: January 02, 2016, 18:45:14 »
There's currently one listed on e-bay for $60 or you can try Vintage Euro parts. They have the whole float assembly for $25 bucks!
http://www.vintageeuroparts.com/100724.html
Jordan
  • Canada, ON, Jordan
« Reply #6 on: April 05, 2016, 14:23:24 »
Does anyone know where to get the o-rings for the reservoir?  This would be the one under the cap and the one wrapped around the body of the sensor (see picture in first post).
After Wallaces talk at PUB last year I know the importance of getting o-rings suitable for the fluid they will be in contact with, in this case brake fluid.
Marcus
66 230SL  Euro 4 speed
« Reply #7 on: April 05, 2016, 20:07:40 »
Nice to know the program was helpful. Good call to be cautious as the standard O-ring material (Nitrile) found in a hardware store would not last long. You would want use EP rubber https://en.wikipedia.org/wiki/Ethylene_propylene_rubber
or SBR https://en.wikipedia.org/wiki/Styrene-butadiene
But normally if it is specified for use in brake fluid, you should be OK.
Jordan
« Reply #8 on: April 05, 2016, 22:10:49 »
Thanks Wallace.  Too bad the EP O-rings cannot, or should not, be used for fuel purposes.  I checked with Vintage Euro Parts and they only sell the entire sensor, not the O-rings separately.
Marcus
« Reply #9 on: April 06, 2016, 01:50:04 »
If you can determine the size, you can buy what you need from Mcamaster. http://www.mcmaster.com/#o-rings/=11uuopq
Recommended materials for Brake fluid (Glycol) that they carry are EPDM, Kalrez with Aflas being almost as good. Just check the material you want in the upper left, and you got it.
