Author Topic: tachometer just stopped working.  (Read 3771 times)
Michaelg
« on: December 18, 2015, 22:41:00 »
Before i start pulling stuff apart, my tach stopped working. What would anybody sudgest for trouble shooting before i pull the tach out to be tested?? Where do i start and finish to pin point the problem.
cheers.
Re: tachometer just stopped working.
« Reply #1 on: December 18, 2015, 22:50:50 »
Broken cable?
Michaelg
« Reply #2 on: December 18, 2015, 23:11:51 »
wow. its machanical?
i may as well start their.
New car for me. been my dads for years. i have a lot to learn!!
ejboyd5
  • Southold, NY
« Reply #3 on: December 18, 2015, 23:41:00 »
Check that both ends of the tachometer cable are still firmly attached as it is possible for the collar to loosen thereby allowing the inner flexible shaft to slip from its driven position.  Did the tachometer make any strange noises just before it stopped working?  Did the indicator needle perform any wild gyrations before quiting?
Michaelg
« Reply #4 on: December 19, 2015, 13:42:09 »
i am not sure i was just given the car by my 90 year old dad.
so i did not see that the tach was broken.
« Reply #5 on: December 19, 2015, 15:10:13 »
What a great gift! Welcome to the world of Pagoda. The tachometer cable is attached to the engine, near and below #1 spark plug. You might want to unfasten it first here, You may be able to see if the cable is intact.
« Last Edit: December 19, 2015, 15:14:43 by ja17 »
glenn
« Reply #6 on: December 28, 2015, 01:42:16 »
Hi, Just had the bushing/bearing at the odometer in the instrument panel freeze up.  A little lube and turning freed it up.
« Reply #7 on: January 02, 2016, 05:09:25 »
The original tach cables have a rubber angle in them right where it connects to the tachometer itself. Mine had deteriorated and fallen apart letting the cable sheath pull away from the tach and take the inner cable along with it.
