Author Topic: Baffled by a wiper problem  (Read 4008 times)
catchersmit
« on: December 23, 2015, 22:01:16 »
My first post as a member! My 64 SL has a wiper problem I can not track down. Motor and wipers run fine when jumped to the battery. Changed out the relay, although old one clicked when stalk was pushed. I cleaned the ground wires near the relay. Cleaned all the contacts on all connections. Power through the fuse checks out. I think motor getting power because when I plug the connector back in at the motor, the wipers park. Anything I missed? Enjoying this site and loving my car!
Re: Baffled by a wiper problem
« Reply #1 on: December 24, 2015, 09:18:28 »
Sort of sounds like a ground problem. You might pull the back cover off the plug, and with it plugged into the motor, jump a ground wire to the ground in the plug. If everything starts to work, go looking for a bad ground connection.
catchersmit
« Reply #2 on: December 24, 2015, 17:27:41 »
Thanks, I'll give that a try. Also noticed that the relay has 5 connections, but the plug only 4. Assume its the correct relay, since the old one had the same. Wonder what that 5th connector is for.
« Reply #3 on: December 25, 2015, 08:25:21 »
Yes this is correct. Only one side of the latching relay is used.
