Author Topic: wood stering wheel and wood dash piece/speaker grill restoration  (Read 6269 times)
Michaelg
I have a beautiful wood steering wheel in my 1970 280 sl as well as a dash piece of wood and speaker grill that need to be re done. or replaced??
I am very handi and have refinished teak in my boat, albeit still a novice, but capable. Have any of you taken on this project. need some guidence.
Sorry for posting in wrong place!!
Happy new year.
Cheers.
Michaelg
« Last Edit: January 01, 2016, 22:16:11 by Michaelg »
perry113
  • USA, NY, Rensselaer
Re: wood stering wheel and wood dash piece/speaker grill restoration
« Reply #1 on: January 03, 2016, 21:39:34 »
What is the condition of the veneer on your 2 dash pieces and how is the speaker.
Can you post pictures of your pieces so I can better advise you?
Regards
Peter Perry
1970 911T Bahia Red
1972 911T Albert Blau
1963 220seb coupe barn
Michaelg
« Reply #2 on: January 06, 2016, 13:15:08 »
here are pics of the grill. The wood dash piece is in good shape. just needs a refinish.
Michaelg
« Reply #3 on: January 06, 2016, 13:18:16 »
second grill photo
Michaelg
« Reply #4 on: January 06, 2016, 13:22:47 »
what kind of finish did this wood have from the factory? glosss is on both the grill and the dash piece as you can see. Is the dash piece glued onto the dash? Should i gently pry it off?
kampala
  • USA, CA, Beach Cities
« Reply #5 on: January 06, 2016, 15:27:30 »
Don't pry the wood -- unless you want to buy new, of course.
Pretty decent write-up in our Tech Manual on how to remove and thoughts on correct finish.
http://www.sl113.org/wiki/Interior/Wood
250sl - later - manual
280sl - 1971 - Auto - LSD
perry113
« Reply #6 on: January 07, 2016, 16:50:08 »
It looks like the veneer is peeling and has broken off in a few areas. It also looks like there is some kind of finish that is on it that has also failed. If all of the flacking is in fact the veneer than I wood say its pretty rough.
You would have to carefully glue and clamp the failed veneer on the backing first.
You can use a variety of small putty knives or smaller dull screw drivers to carefully knock of the loss failed finish coat on the wood without damaging the veneer. You can then use 1000-1500 grit wet sand paper to prep however it is so tedious and time consuming. If you have the time and patience then go for it.
If time is an issue then it might make more sense to replace. I recently purchased a new on from Vintage Euro Parts and was pleased with the product.
See here:
http://vintageeuroparts.com/100411.html
I hope this helps.
« Last Edit: January 07, 2016, 17:00:12 by perry113 »
Peter Perry
1970 911T Bahia Red
perry113
« Reply #7 on: January 10, 2016, 02:26:46 »
I just finished up the final clear coat on a new dash for my father's Morgan. My next set of wood projects are the original center consoles on the 65 and 66 230sl's. I am leaning on doing them like the Morgan Dash which went through 3 separate rounds in the paint booth with Omni clear. Its a a lot of work doing it this way but the results are worth it.
Peter Perry
1970 911T Bahia Red
Pinder
  • USA, NJ, Edison
« Reply #8 on: January 10, 2016, 02:42:22 »
the morgan dash looks great. I think these old 113s have a almost semi gloss finish. sort of hand rubbed with grain showing. Not sure how to achieve it but will get to mine at some point. For now I used minwax stain and left it at that.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
perry113
« Reply #9 on: January 10, 2016, 15:26:59 »
I may in fact do the semi gloss finish on the 113 pieces. It is done the same way except you use a semigloss clear or use a flattening agent. The main key is ever so gently prepping the wood without damaging. One of my consoles has some type of old finish on it that will have to be removed. I will post more info as I make progress.
« Last Edit: January 10, 2016, 15:33:03 by perry113 »
Peter Perry
1970 911T Bahia Red
Pinder
  • USA, NJ, Edison
« Reply #10 on: January 10, 2016, 18:16:02 »
Great, I will definitely look out for the progress you make and gets some tips from you.
