Author Topic: need some help  (Read 2150 times)
piddler
need some help
« on: January 11, 2016, 11:52:22 »
I am in southwest Virginia and I would like to find a mechanic to help get our '67 230SL tuned up. The car is an automatic with fuel injection. It has been sitting for quite a while and that might be part of the problem.
As always, any and all help appreciated, Pete
Rolf-Dieter ✝︎
  • Canada, ON, London
Re: need some help
« Reply #1 on: January 11, 2016, 13:41:28 »
Hi Pete,
Go to the Members list (link below) click on "Location" once the table opens, then go to the page showing Members near you and drop one or two of them a line to find out the mechanic they are using.
Link ----> http://www.sl113.org/forums/index.php?action=mlist;sort=location;start=2050
Most likely your linkage needs adjustments I had similar issues when I got my car.
If you are lucky someone from your area will respond to your post. Also go to our Technical Manual and have a read in the "Linkage Tour"
Linkage tour ----> http://www.sl113.org/wiki/Restricted/Linkage-tour
Good luck!
« Last Edit: January 11, 2016, 13:46:31 by Rolf-Dieter »
