Author Topic: Windows of the doors  (Read 4410 times)
mda
  • Russia, Moscow
« on: January 23, 2016, 16:56:17 »
Hi.
I am unhurriedly building a car after repainting. I can't find screws for window glass (fixture for a window lift) I can't find a photo on the forum. Could anybody show me photos of screws (in details) or how to fix window to lift.
Thanks.
Re: Windows of the doors
« Reply #1 on: January 24, 2016, 06:29:12 »
If you check the websites of the better suppliers, such as SLS, you will find parts drawings that show all the hardware. Most everything is still for sale and I think this includes most if not all the nuts, washers and bolts for the windows. Good luck,
travellerdogs
  • Canada, British Columbia, Bowser
« Reply #2 on: January 24, 2016, 09:13:05 »
I am fixing my passenger door glass slides and need the small teflon inserts in the aluminum slide blocks that are glued to the bottom of the window glass and also for the small chrome guide at the top front of the door. you mentioned a supplier SLS. Where do I find their website and what is their proper company name. Thank you, Carey
travellerdogs 1969 280SL,  1981 380SL:  1955 HD Panhead: 2007 HD Street Glide: 1956 Mercury Montclair, Black 2 Dr Htp; 1965 230SL: 2005 Pontiac Sunfire: 1993 Range Rover: 1977 450SL parts car:
« Reply #3 on: January 24, 2016, 10:24:27 »
Quote
Hi.
Pictures and shopping list for screws attached.
The door glass guides are listed in the tech manual:
http://www.sl113.org/wiki/ChassisBody/Windows
You can order them by part # from your local MB dealer etc.
« Last Edit: January 24, 2016, 12:11:52 by Peter van Es »
« Reply #4 on: January 24, 2016, 17:40:55 »
I recently bought a couple of parts for my door windows including the inserts - I'm not sure but I believe I got them from Niemoller rather than SLS. If you google 'SLS Hamburg' and 'Niemoller mercedes' their sites should pop up - or check our vendor database, they should be in there as well. Good luck,
travellerdogs
« Reply #5 on: January 24, 2016, 23:38:59 »
Thank you Cees. I will check them out.
mda
  • Russia, Moscow
« Reply #6 on: January 25, 2016, 05:51:39 »
thanks guys! the photo helped!
batman
« Reply #7 on: January 25, 2016, 11:32:09 »
I bought 2 sets from SLS last year when I replaced all and they fitted perfectly.
see: http://www.sls-hh-shop.de/en/230-280SL-W113/
cheers
