All, I had my fuel pump, cold start valve, rebuilt and injection pump calibrated. I now have no power at the fuel pump when I turn on the ignition switch. I did remove all gauges to replace capillary tube as well. I show power at the fuse box but nothing at the fuel pump wires with the test light? center gauges, and speedo are back in but waiting on flasher relay switch before putting tach back in. Would this cause my no power at fuel pump wires? Pump will run using external power. thanks for any help the team can give. 69 280 sl
