Author Topic: help wanted locating coorect firewall pad for RHD w108.057 (1972 280se 3.5)  (Read 4654 times)
rutger kohler
The firewall pad on my car above needs replacing.  The surface of the firewall pad is quite different to the pagoda.  Instead of being a diamond pattern I would describe it as shallow "craters" about 5/8" or 16mm  diameter. The firewall pad is not large and could be cut from the material if cut to fit versions are not available.
1969 280 SL Manual gear shift
1972 280SE 3.5 auto
perry113
  • USA, NY, Rensselaer
It is available from Mercedes Classic. I bought about 4 or 5 years ago for my low grille 1970 280se coupe
Peter Perry
1970 911T Bahia Red
1972 911T Albert Blau
1963 220seb coupe barn
rutger kohler
Hi, thanks for that.
1972 280SE 3.5 auto
