Become a
Full Member
Emergency Contact List
Electrical and Instruments
Flashers/signal lights
Topic: Flashers/signal lights (Read 4508 times)
catjim813
February 01, 2016, 01:51:11 »
All, what would cause the flashers not to work when switch is activated? signal lights work fine. I replaced the flasher relay six prong switch but still the flashers will not work. Is there a second flasher relay switch on a 69 280sl?
Kayvan
Re: Flashers/signal lights
February 01, 2016, 03:58:29 »
Did U check the auxiliary fuse box; small square brown box with knurled screw.
It controls some lighting functions
Inactive
Platinum
USA, CA, Encinitas
Reply #2 on:
February 01, 2016, 04:41:07 »
Catjim, Have a look at this thread. There are multiple ways the hazard and turn signals can be wired. All depends on year and if it was a US or Euro model. Lot of variables. Looking at the wiring diagram there is a seperate relay or flasher. It may or may not involve the hazards. No matter the hazards are fed from fuse #1. Always powered.
http://www.sl113.org/forums/index.php?topic=17648.0
Last Edit: February 01, 2016, 04:46:03 by Tyler S.
catjim813
Reply #3 on:
February 01, 2016, 16:48:45 »
Kayvan, and Tyler I will look at both once I get home from work. The bracket is already down from putting in the capillary tube so I should be able to see the wiring and see if there is a second relay switch. Thanks for the follow-up
Kayvan
Reply #4 on:
February 01, 2016, 17:42:42 »
FYI see Manual too...may help
Last Edit: February 01, 2016, 22:14:49 by Kayvan
Inactive
Platinum
USA, CA, Encinitas
Reply #5 on:
February 01, 2016, 22:00:29 »
Kayvan, I think he is going after the hazard-flashers. He mentioned the signals and the 6 prong switch (hazard switch)
