Author Topic: 1970 280SL Rear differential and Engine Revs  (Read 2992 times)
w113abudhabi
  • United Kingdom, England, Wigston
  • 1970 280SL Papyrus White / Red
« on: February 03, 2016, 10:25:40 »
Taken from a separate thread:
"the non-US 280 SLs started out with a 3.92 ratio (US ratio was 4.08), then at chassis no. 011132 the non-US cars went to 3.69 while the US cars went to 3.92.
With the 3.92 my car shows 70 mph (110 kph) at 4000 rpm."
I am enjoying driving my US spec 1970 280SL with automatic transmission which has a 3.92 ratio diff. I notice that at highway speeds (70-80mph) the engine revs are fairly high and comparable to the quote above. Would I derive any significant improvement by changing the diff for an alternative ratio?
Any comments or suggestions please?
Rolf-Dieter ✝︎
  • Canada, ON, London
Re: 1970 280SL Rear differential and Engine Revs
« Reply #1 on: February 03, 2016, 15:12:25 »
Some of what you seek can be looked up here
---> http://www.sl113.org/forums/index.php?action=dlattach;topic=18239.0;attach=20119;image
I am quite happy cruising around 3,200 RPM in my 1969 280sl to change would not make too much of a difference in MHO ... If I like to go faster I'll take my DD :) besides to change would make my car no longer original.
w113abudhabi
« Reply #2 on: February 04, 2016, 05:18:49 »
Thanks Rolf-Dieter
I was hunting for info yesterday and read a few related threads. It would be good if the graph you linked could be stored in the Technical Manual which I was looking through yesterday prior to posting.
It suggests to me to leave my car as it is as the benefits are relatively little. Where I live currently it is necessary to use the highway regularly although I anticipate that will change in due course and on country roads I may well prefer the existing and original set up.
Best wishes,
Pierre
« Reply #3 on: February 04, 2016, 11:29:04 »
As a full member, you can add the graph in the Technical Manual yourself...
w113abudhabi
« Reply #4 on: February 04, 2016, 13:46:03 »
Oh really. Then I shall do so. I didn't want to step or drive on any toes...
