Author Topic: Brake booster vacuum hose  (Read 5191 times)
Clayton
« on: February 04, 2016, 18:58:17 »
I could not find this part in past posts. So, does anybody know where to find the transparent white hose that goes between the brake booster and intake manifold on a 1969 280? Before, I found a 3/8 ID hose, heated it up and forced it over the couplers. Got to be a better way.
WRe
Re: Brake booster vacuum hose
« Reply #1 on: February 04, 2016, 21:21:33 »
this part (no. A1134300629) is still available at MB (~27€).
...WRe
Mike K
    • Mike Kirkinis
http://michali.zenfolio.com
Pinder
  • USA, NJ, Edison
« Reply #3 on: February 05, 2016, 03:21:50 »
What I did with mine is replace it with a semi transparent whitish hose that you can get from Home depot in the pluming department its the same material Size and color.   If you need a new one way valve and end fittings then there is one on Autohauz AZ in black color.  Some people mentioned they would not trust the quality of the material of the hose I discovered at home depot. I personally think its the same material. for 25 feet of the hose it was around $8.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
« Reply #4 on: February 05, 2016, 04:18:33 »
Pinder, I remember someone saying your hose wouldnt hold up. PE (Polyethylene) is used for water, Gas lines, and even hydraulic fluid return lines. I think it will be just fine.
Pinder
  • USA, NJ, Edison
« Reply #5 on: February 05, 2016, 09:39:04 »
Me too. :) I'm 99% certain its the same material Same inside diameter. Both the 69 and 70 both had the same semi transparent line used. Some say that it is supposed to be black in color but Im not convinced that is true in all cases. Probably many different types used.
Clayton
« Reply #6 on: February 05, 2016, 15:08:49 »
My SL brothers to the rescue. Thanks! Is that OEM replacement semi transparent and cad plated? Maybe just a bad pic because the hose looks black.
« Reply #7 on: February 05, 2016, 15:19:29 »
Clayton, Some are black and some are white. Whenever I see an "A" before a part number I always double check the listing and description. Could be aftermarket. Here is a genuine Mercedes hose and its the white version with Cad. https://www.ecstuning.com/ES1638087/?gclid=CjwKEAiArdG1BRCLvs_q-IObwxMSJACXbLtzB5oH3AOzekUhwxPCNfnUVwKX_oKjUqPjvEpMypIuZhoCTTDw_wcB
49er
  • USA, CA, El Dorado Hills
« Reply #8 on: February 05, 2016, 16:54:34 »
My early '69 has a black vacuum hose.
John
1969 280SL 003820
Mike K
    • Mike Kirkinis
« Reply #9 on: February 05, 2016, 21:13:20 »
The one I replaced in my 1971 280SL and the one I purchased on ebay in the link I posted above are both black with the correct fittings.
Mike
