Author Topic: Brake Fluid Reservoir Cap  (Read 4607 times)
Jordan
  • Canada, ON, Jordan
« on: February 08, 2016, 16:47:48 »
An easy question to which I do not know the answer.  Are the two (they are off white) outside brake fluid reservoir caps (the one with wires coming out of them on 280SL's) suppose to have a rubber gasket or some form of washer under the cap to seal them when screwed closed or not?  I can't find a picture anywhere that answers this question so if someone could have a look or knows please let me know.
Many thanks.
Marcus
Marcus
66 230SL  Euro 4 speed
mbzse
Re: Brake Fluid Reservoir Cap
« Reply #1 on: February 08, 2016, 16:56:02 »
Quote from: Jordan
.../...outside brake fluid reservoir caps (the one with wires coming out of them on 280SL's) suppose to have a rubber gasket or some form of washer under the cap.../...
The black plastic parts (cylinders) to which the wiring is attached has a groove on their perimeter, in this groove goes a rubber seal ring (O-ring).
/Hans in Sweden
« Last Edit: February 16, 2016, 11:13:36 by mbzse »
/Hans S
Jordan
« Reply #2 on: February 08, 2016, 20:30:03 »
Hans, I am not sure that is the same reservoir.  The caps I am talking about are the bottom two you see in the picture below.  I'm not sure if there is an o-ring or rubber gasket that goes up inside the cap. Ignore the reservoir you see in the picture,  I am talking about the 3 cap type with those white caps on each end and a black cap in the middle.
Marcus
mbzse
« Reply #3 on: February 08, 2016, 21:24:21 »
Quote from: Jordan
../...I am talking about the 3 cap type with those white caps on each end and a black cap in the middle
You wrote "the one with wires on 280SL´s"; so that type is what my reply refers to
/Hans in Sweden
/Hans S
« Reply #4 on: February 09, 2016, 00:32:12 »
No there is no washer or o-ring on the 2 caps. They are just there to hold the electrical float housing down into the reservoir.
Jordan
« Reply #5 on: February 09, 2016, 00:48:20 »
Thanks Tyler.  Saves me from having to look for washers or o-rings.
Marcus
