Sometimes I set the bracket in the dash before installing the tach. You can also squeeze the bracket legs slightly together so it grips the tack and stays in place while your trying to install the ground wire an thumbscrew. As last resort, remove the front seat, lay a nice thick pad down, so you can lay on your back and work comfortably. You can actually see what you are doing with some good light.
