Author Topic: Rear axle pivot shaft - how to remove wedge bolt?  (Read 12843 times)
cfm65@me.com
  • Cape Town, South Africa
Re: Rear axle pivot shaft - how to remove wedge bolt?
« Reply #25 on: May 01, 2016, 18:17:41 »
Well done, Star 63,
Please tell me about the Benz Dr's jack trick. I assume that the bronze bushes cannot be replaced with this procedure. I need to replace both bronze bushes and the large pin as well as the large rubber bushing. Did you use the clinometer to adjust the rear axle tube horizontal and then the hanger arm vertical?
Regards
Chris
Cape town
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
star63
  • Finland, Etela-Suomen Laani, Vantaa
« Reply #26 on: May 01, 2016, 18:52:30 »
If you also have to change the bronze bushings you probably must take the whole axle down.
I used the clinometer readings to adjust the vertical support 90 deg from the left axle tube (which was not horizontal at that point).
Benz Dr's advice: Place a hydraulic jack under the right hand side bracket of that spring. While supported by the jack, loosen the inner bolt of the bracket just a little. Then remove the outer bolt. Lower the jack slowly and the bracket will pivot around the inner bolt. Now, it's easy to take the spring out.
Petri
'67 250 SL (early)
'66 230 SL (long project)
Finland
cfm65@me.com
« Reply #27 on: May 12, 2016, 10:21:17 »
TKS Petri,
That is how I fugured to remove the compensating spring.
However, the trick is now to get it back in position.
Regards
Chris
« Last Edit: May 12, 2016, 10:36:05 by cfm65@me.com »
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
