Become a
Full Member
Emergency Contact List
Electrical and Instruments
Mystery box in front of fuse panel
Topic: Mystery box in front of fuse panel (Read 5233 times)
john matteucci
February 28, 2016, 20:39:04 »
Would someone be kind enough to help me identify the small box in front of the fuse panel on the firewall. It appears to have 2 brackets inside. This box is on the driver side between the fuse panel and the round black relay. Many thanks in advance
Inactive
Platinum
USA, CA, Encinitas
Re: Mystery box in front of fuse panel
February 28, 2016, 21:12:58 »
If this box in question has a thumbscrew and cover that can be removed, It is a small fusebox. If it is a USA model, 68 or older it is the fuse box for the front fog lamps inside the AC style headlamp doors.
Tyler
Last Edit: February 28, 2016, 21:21:58 by Tyler S.
jameshoward
Associate Member
Platinum
United States, New Jersey (formerly of London)
Reply #2 on:
February 28, 2016, 21:27:36 »
A picture would help!
James Howard
1966 LHD 230SL
john matteucci
Reply #3 on:
February 28, 2016, 21:42:59 »
Quite right! Attached (I hope) is a photo of the box with the cover removed.
1964 230SL Date of production: 12-23-63
Inactive
Platinum
USA, CA, Encinitas
Reply #4 on:
February 29, 2016, 00:27:01 »
Yep, Thats it. Put an 8 amp fuse in there and see if your fogs work. You need to put your headlight switch in position 1 or 2 and pull the knob to activate. Try both positions as sometimes they are wired differently.
Tyler
Pagoda SL Board
Platinum
USA, CA, San Marcos
Reply #5 on:
February 29, 2016, 16:03:43 »
Hard to tell from the photo, but isn't the back spring tab missing? The fuses have cone shaped ends and should fit into a spring clip on each side.
Full Member
Platinum
USA, CA, Solana Beach
Reply #6 on:
February 29, 2016, 17:35:24 »
It does not have to be a fuse box for fog lights it can also be an auxiliary fuse box for the radio and/or power antenna.
Search for "auxiliary fuse box" and you'll get many different answers!
1966 230SL automatic 334G light blue (
sold
Inactive
Platinum
USA, CA, Encinitas
Reply #7 on:
February 29, 2016, 17:47:28 »
Alfred, Yes, but those are usually on the passenger side.
