Two points to ponder.
There is also another good reason for unhooking the power feed to the start sol. on the early pumps [Up to and including R18]
And it is a mechanical reason .
The lever that is actuated by the sol is mounted on a stub shaft [ meaning it has support only at it's base] , so as they age, they snap off from the constant/repeated snap of the electric sol. ...and when they do break, the loose parts can then destroy the bottom end of the pump, casing included.
I have repaired some of these that were caught before being ruined by adding a support hole in the case and making a longer shaft to reach the new support hole. The new shaft then has support on the other end [ now both ends are supported]
This eliminates the possiblity of shaft failure , but is a machinest job that requires the proper equipment. Not an easy job.
The point being, the easy remedy and preventive measure is to eliminate the sol function [ by wire disconnect] , and simply add the newer style Ball valves. You will notice that all pumps that came with the ball valves upgrade [ after R18] do not have a factory sol . B/C it is waqs longer needed.
While here , I will state that I also have had much better luck over the years of using the Cabin switch for the CSV. [ As many of you already know the advantage of taking control of whether the engine wants gas or doesn't]
So, it is the simply an electric primer, manually activated ...
But here is the trick to much better starts.
Do not wire the CSV cabin sw to the existing relay/circuit or starter circuit.
Simply wire it to key ON .
This allows CSV actiavtion BEFORE starter draw, engine crank.
The start process is
1- Key ON for a sec or 2, [ this pressures the system]
2-Cabin sw if needed [ that depends on situation..cold start , warm start, etc.]
3-Then Crank.
The plenum is now already primed before you even turn the engine over.
Much faster starts and a better CSV operation b/c there is no system voltage drop from starter.
Another trick I like about this wiring system is that if one suspects a CSV problem, you can hit the cabin sw when the car is warmed up and running and you will instantly know if it is working correctly b/c the engine will attemp to stall from the added CSV injection...just a diagnostic by- product with this type of wiring of the cabin sw/csv circuit.
BenzTechs
