Author Topic: Pagoda World 18  (Read 12448 times)
68_white
  • USA, TX, Houston
Re: Pagoda World 18
« Reply #25 on: March 27, 2016, 13:34:41 »
Got mine last week. Love those stickers.
HARRY
1970 280SL RED
2002 E430 SILVER
1996 911 BLUE
neelyrc
  • USA, AL, Birmingham
Re: Pagoda World 18
« Reply #26 on: March 28, 2016, 04:42:43 »
I became a full member a few days before the mailing date.  Did I make the cut for the mailing list?
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
Rolf-Dieter ✝︎
  • Canada, ON, London
Re: Pagoda World 18
« Reply #27 on: March 28, 2016, 05:04:14 »
Hello Ralph,
Sorry about that, you became a full member Jan 10, 2016. PW issue 18 was posted in the beginning of March. When I joined I ordered some back issues like issue 10, 11 and 12 and I am glad I did. If you like you can do the same. We always do have some back issues left. Issue 15, 17 and 18 are very good (as all our issues are) issues and you can order them if you like. Should you need the link I add it below.
Click here ----> http://www.sl113.org/forums/index.php?topic=11537.msg77316#msg77316
You will get issue 19 in the fall. I did mail you two window stickers with issue 16 as I recall I hope you enjoy that one.
Cheers,
Dieter
Edit ... Corrected typo
« Last Edit: March 28, 2016, 12:23:09 by Rolf-Dieter »
neelyrc
Re: Pagoda World 18
« Reply #28 on: March 28, 2016, 06:09:16 »
Thanks Dieter, I will follow up on the back issues.
Ralph
Ralph
Italy
Re: Pagoda World 18
« Reply #29 on: March 29, 2016, 14:11:34 »
Finally arrived on Friday, March 25.
I see that it came "Standard Mail" which was the reason for the time delay; it took 15 days to get to my mailbox. Those who reside overseas probably had theirs sent by first class which explains why those in France received theirs on March 20.
Standard Mail (domestic use only), also known as "bulk mail", is processed by the USPS on a “time available” basis. Standard mail is not forwarded or returned if undeliverable unless a special endorsement is used. Standard mail will typically be delivered in under 5 business days locally, but nationwide it could take 2 to 3 weeks. Standard Mail should not be used for time-sensitive mail. As with Presorted First-class, to receive the lower postage rate, the addresses must be NCOA updated, CASS certified, and put into presort order.
Standard Mail is the least expensive postage mode, approximately 32 percent less than the price of first class. Standard mail postage rates apply to mail up to 3.3 ounces. Mail heavier than 3.3 ounces will have a small weight surcharge.
